Issue with Design Extender and Menu Writer
Thread begun 3/19/2012 5:50 am by Jon Cunningham | Last modified 3/19/2012 8:39 am by Jason Byrnes | 1270 views | 1 replies |
Jon CunninghamBeta Tester
Hi Guys,
I have an issue with design extender (Menu Writer).
Before I start I would just like to mention that this has happened on two different PC's both of which run CS5.5. and I have followed the correct installation order. (I have deleted the Configuration folder and reinstalled all extensions)
Due to time restraints I have had to uninstall design extender and install each extension individually so that I can meet deadlines.
The issue:-
I have created a new 2 DW Template with the following editable regions
Template 1
Header
Navigation
Footer
Template 2
Header
Footer
Using both templates, without adding a menu (Menu Writer) prior to running DA
Run DA to create pages. No Issues
When using both templates which have a menu (Menu Writer) prior to running DA the outputted code breaks.
Please see attached file of generated code.
Since I have uninstalled drive extender I don’t have time to trouble shoot this issue. Just hope you guys at WA can try and recreate this and provide a fix.
Kind regards
Jonathon
please send a copy of the templates you are using and all of the supporting files so that we can try to reproduce the issue and find the cause.
