Design Extender CMS Serial Number
Thread begun 3/17/2012 2:16 pm by ron.haysbert231945 | Last modified 3/18/2012 8:42 am by Ray Borduin | 2487 views | 3 replies |
ron.haysbert231945
received this message: ERROR: PowerCMS cannot activate without cURL installed and functional on your PHP server. Please activate cURL before attempting to proceed.
What does this mean??
Roanld
uncomment the line:
;extension=php_curl.dll
(by removing the semi-colon in the front) in your php.ini file, and then restart the server.
ron.haysbert231945
cURL
Thanks Ray:
I uncommented the line as you said in the php.ini file.
Received the attached error message.
C:\wamp\bin\php\php5.3.10\php.ini is this the right location.
Create a new page with just this code on it:
phpinfo();
Then view that page... it will tell you the correct location of the php.ini file. Based on your result you have probably edited the wrong one.
