Missing MD5 in Email Password
Thread begun 3/13/2012 11:41 am by Cologne | Last modified 3/14/2012 12:33 pm by Jason Byrnes | 3039 views | 5 replies |
Cologne
MD5 encoding ist missing in the Email Password Wizzard :-( I only can choose HASH.
Please help.
Denis
For MD5 encryption you need to use the Email Encrypted Password behavior under Webassist -> Security Assist -> Email Password -> Email Encrypted Password.
Cologne
Hey Jason,
ok, I made it with the Return Email Wizzard. And it works fine.
But what do I have to do with the "Return Page". I inserted the Return Email server behavior, and then?
Do I have to create an update form in that page? So the user can change his password?
Where is "fp_data=4b780a05d34d10ee2266ff462f9bb4b4" stored? In my table? but where?
How do I get the ID, to update my table?
I need some help here, please.
Is there a tutorial?
Cheers,
Denis
on the return page, you need to add the encrypted password return behavior which will look up the user record.
the fp_data string is created by first concatenating the fP_id and fb_email values, then encrypting that string based on the encryption type used.
the encrypted password return behavior looks up the user record based on the fp_id and fp_email variables. it then concatenates the ID and email columns into a string and encrypts it.
that encrypted string is compared against the fp_data string to make sure they match
in addition to the email password return behavior, you need to add an update form to change the password.
you need to add an update record behavior to update the password ion the database based on the fp_id querystring variable.
it would be a good idea to create the email password page using the wizard as a pint of reference before trying to create it manually.
Cologne
Hi Jason,
if I understand right, the return page behavior, just checks it the link is ok, and it seems to be the user, right?
so then, if its all ok, my update record form will be shown and the user can choose his own new password?
for ID-Key I use the get[fp_id] ?
encrypte the password and update the table, right?
Cheers,
Denis
yes, that is correct. like i said, if you use the wizard to create the pages for you, you will have a frame of reference to use.
