DA Update page redirect wrong?
Thread begun 3/13/2012 8:14 am by gary.brett434358 | Last modified 6/20/2012 10:12 am by Jason Byrnes | 5093 views | 11 replies |
gary.brett434358
Hi, for whatever reason, one of my update pages has started redirecting to an incorrect page, I only noticed today may have always been like it!
On the server behaviours 'update record' it is set correctly to redirect to:
tblcontacts_Results_Direct.php?ContactID=<?php echo ((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:""); ?>
However the page redirects to 'tblcontacts_Update.php', I have searched the up[date page endlessly and can find no reference to this page, have used IE & Chrome, cleared cache with no success?
// WA Application Builder Update
if (isset($_POST["Update_x"])) // Trigger
$WA_connection = $ghl_portal;
$WA_table = "tblcontacts";
$WA_redirectURL = "tblcontacts_Results_Direct.php?ContactID=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "ContactID";
I have attached page if anyone can help me out?
Many thanks
Beau
I'm not for sure if it's the same problem... But after updating DataAssist the redirect url stopped working. After saving the record the page would reload itself instead of going to the redirect url specified. Discovered that rel2abs was changing the specified redirect url to an absolute path that did not exist causing the redirect to fail. I deleted the call to rel2abs (shown below) and the redirect url started working again.
here is an updated copy of the WA_DataAssist/library.php file that should correct the problem.
doug.lemesurier305760
Redirect... does not
Same problem.
The redirect, after update, does not redirect. It just reloads the same page.
I've tried removing: if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
I've replaced the DA Library.php but I just can't get the redirect to work.
could be a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
Some old-school weirdness here.
1. I made sure the updated DA Library.php was correct - no effect.
2. I turned on the error reporting in 2 pages - one UPDATE page and one INSERT page.
3. Tested and BANG, the UPDATE page redirects correctly with no errors. 'A cache issue' I think, and I switch browsers to validate... all goes well.
4. Now I test the INSERT page, with the error reporting code snippet, but it does not redirect to to the value in $WA_redirectURL = "index.php", it just re opens itself.
I am now going over the INSERT page. No errors are reported but there must be a coding issue.
send a copy of the insert page please.
Here's the file. Note: I've left the PHP error reporting at the top
at line 27, there is a blank line between code blocks. Line 25 - 30 is"
$WA_menu_1287605593074->Initialize(true);
// WA Application Builder Insert
if (isset($_POST["Insert"])) // Trigger
that blank line between code blocks can cause redirects to fail, delete the blank line at line 27:
