I have problem in implementing Coupon in Power Store 4.5
Thread begun 3/12/2012 11:37 pm by fbms | Last modified 1/01/2014 1:11 pm by Jason Byrnes | 6248 views | 12 replies |
fbms
Dear Technical Support,
I have installed Power Store 4.5 fill in some fake products and want to implement Coupon feature for all the products in the store.
Reading description how to set up coupon feature from online tutorial and follow the steps provided.
When I enter the coupon code for specific product/s ordered, and it suppose to deduct the total order amount but it did not work, the total amount still the same as before.
Example of the coupon paremeters content value:
Live? yes
Coupon Code: ticfam
Minimum Purchase: $1.00
Amount: $1.00 (up to $1.00)
Available Dates: 07/20/2011 - 07/01/2012
For Products: all
Description: Coupon for buying family ticket choice
Is there anything wrong in my setup above?
Where I can find additional information/example how to set up Coupon Feature?
Thank you for reading my email, and I am looking forward to hear from you.
Regards,
FBMS
newsletters437094
My partner and I are having a site designed using your cart and have also noticed issues with the coupon codes.
I had first thought I encountered the exact problem that is posted here and after some further playing around with the coupon codes, I also found that when you select specific products for a coupon code to apply to, the code always saves the selections as 'all products'.
This has caused us a great amount of concern, since selecting specific products to have a sale on is a critical feature that we require.
Any idea how to fix both of these problems?
here is an updated copy of the admin/scripts/products_results.js file that should correct the issue with applying the coupon to certain products.
for the issue with the coupons functioning:
tim299030
This post has been deleted.
info290144
Powerstore coupon is not working
Did you ever solve this coupon issue? I have the same problem in PowerStore 4.5. When I enter the coupon code I created at check out the discount is not applied.
tim299030
I believe Webassist had to update the files. Everything has been working fine for me since they made the update.
info290144
I have just updated the file but still the issue is not solved for me.
info290144
Info given in private section. Thanks
