Pro Maps Info Window Problem
Thread began 3/12/2012 1:09 pm by kevin389160 | Last modified 3/21/2012 3:56 am by mileslimon437271 | 1326 views | 2 replies |
kevin389160
In Pro Maps for Google the Info Window that appears with the address in it used to have rounded edges and now after I updated to Design Extender 1.0.2 the Info Window appears with squared edges. Can you please help me fix this as I do prefer the rounded edges.
You can see this at map.php
the pro maps version of Design Extender uses the newer Google Maps v3 API, Google does not offer a way to use rounded corners for the infoWindow in this version of the API. This is a limitation to the API.
mileslimon437271
I have checked mine Its working fine..
Rancho Santa Fe
