Pre-Purchase Question
Thread begun 3/12/2012 5:48 am by johna1964 | Last modified 3/13/2012 8:43 am by Ray Borduin | 1888 views | 4 replies |
johna1964
Hi!
Can I use an emulation of Authorize.Net? In other words, because of the "risk" factor relating to the product, I had to change change the URL they access from
transact.dll
to
order.pl
when using ecart. It worked with ecart and still works, but I would like to use this with Power Store.
Is this possible?
Thank you!
johna1964
I don't see why that wouldn't work... you could probably just do a find and replace on the files. It probably only appears once in the authorize.net include. I think the emulator uses the exact same structure, so it should all still work.
johna1964
Ray,
That will work!
Thank you!
johna
johna1964
Another Quick Question
I need to make sure I can add a birthdate text field in the registration. Is that possible?
Thank you again.
johna1964
Anything is possible, if you know what you are doing. This is not a directly supported feature and would require edits to the page with dreamweaver and either editing server behaviors or hand coding.
It is certainly something we could help you do in a premium support ticket if you weren't able to do it on your own.
