File Permissions problem on Install
Thread begun 3/09/2012 11:30 am by lr_leal239405 | Last modified 7/23/2012 11:57 am by Jason Byrnes | 4908 views | 7 replies |
lr_leal239405
When trying to run the install for PowerCMS I'm getting:
File Permissions
Files and directories cannot be created. Verify the PowerCMS directory has write permissions on your server.
Files cannot be created in the PowerCMS/Connections directory. Please ensure that directory has write permissions on your server.
The hosting co. is telling me I have full permissions. This is being installed on a Windows server so they're asking me to find out if it's compatible. Also, I noticed there is no directory called PowerCMS/Connections. There is a Connections folder in which the PowerCMSConnection.php file was placed in. I'm assuming that's the folder that needs the permissions but hosting co. already confirmed that. What else can I do?
thank you.
the error is saying that folder that contains the power cms files does not have write access. that would be the folder the contains the power CMS install folder.
if you access the install using the url:
index.php
the folder that needs to have full access is the /pcms/ folder.
the connection folder gets created by the install script, it wont exist until you have completed the install.
lr_leal239405
There is no folder called pcms or PowerCMS anywhere plus according to hosting co. the folders install_cms and cms which were created by the software have full permissions. But stilll won't run. It is on a Windows server. Could that have anything to do with it?
i wasn't necessarily saying there would be a folder called cms. i was trying to give an example of a possible path to help you find the correct folder.
lr_leal239405
the web user permissions was the problem. I was able to install it. Thanks for your help.
great, glad to hear it is working.
marketing331920
Permissions Installation Wizzard
I have the following error on the installation wizard.
" File Permissions
Files and directories cannot be created. Verify the ../ directory has write permissions on your server."
Thus I have two very important questions:
1. Exactly which folder or folders need to the 777 permissions?
2. Is there a securty breach that we should be aware of and if so how do we protect the data from such a breach.
I am new to using the SuperSuite products so I ask kindly, speak in "tiny" laymens terms.
I do appreciate your products and I am reading Dummy books and others to try to come up to speed.
1. the folder that contains the CMS Files needs to have write permissions to complete the install,
specifically, that would be the folder that contains the install_cms folder on your site.
2. to prevent any security breach, once the install has completed, the permissions to that folder can be set back to the original.
after the install is completed, install the images_upload folder will need to have write permissions.
