Browse Server for Link/Image Error
Thread begun 3/09/2012 10:34 am by debbie295402 | Last modified 3/09/2012 11:42 am by Jason Byrnes | 7463 views | 10 replies |
debbie295402
On a currently working site, when I click on the insert link or insert image buttons and then click on browse server I get the following error on a separate page:
alert("MDB2 Error: no such table\nSELECT extension, plugin FROM kfm_plugin_extensions WHERE user_id=1")
I've currently had issues with versions of PCMS so I've installed Design Builder. I don't know if the 2 are related.
Is this a db back end fix too? I have a picky client (likes to find fault with almost everything) waiting for this so any quick help would be appreciated!
site is www.zontadistrict9.org. cms is at /admin_cms
this happens if you move from an older version of CMS to a newer one.
In the CMS database, delete all of the tables whose names begin with "kfm_". they will be recreated the next time you open the file manager.
debbie295402
and that won't remove any existing data?
not as long as the ONLY tables deleted are the ones that have names starting in "kfm_"
all of the CMS data is stored in the tables whose names begin in "pcms2_" as long as you leave those tables untouched, you'll be fine.
debbie295402
Got it. Now with the tables gone the Please Wait - loading ... has gone on for over 5 minutes or more.
in the webassist/kfm/index.php page
find the following line:
<script type="text/javascript" src="j/all.php/can-minify"></script>
and change it to:
<script type="text/javascript" src="j/all.php"></script>
debbie295402
That gave me the directories. Now, when I click on the Browse, then Upload File: browse button, I get the directory structure and when I click on a file and select open it says file 1: 100% and then a bunch of errors: message from webpage, like id SWFUpload_0_0, post [object Object], etc., but no file that I can see...
debbie295402
ok, now it let one in and seems to be working for me for 2 different files in different directories
debbie295402
It seems to be working correctly now. It was like it gave me a message for each field it populated for the file
