Multiple category/subcategory Adding
Thread begun 3/08/2012 3:46 am by martin400112 | Last modified 3/08/2012 6:47 am by Jason Byrnes | 1479 views | 1 replies |
martin400112
Not sure if this is the right forum to place this post, but....
I have an issue with a client adding products to multiple categories and subcategories with an e-cart created shopping site. I have attached the files for you to see as I can't find anything wrong!
Here's how it works:
Step One: Client adds a product on the product insert page.
Step Two: The product details are sent to page 'product_categ_inset.php' which uses a multiple record insert behaviour to add the product to the various categories the product needs to reside in.
Step Three: Following the category insert, the product details are sent to page 'product_SubCateg_insert.php' for a multiple subcategory insert behaviour.
The problem is that this process seems to only work sporadically ie, when we were testing it out yesterday, we managed to insert 4 products successfully into the products, category AND subcategory tables on the database. After that, the products would insert ONLY into the product table and not the category or subcategory.
As it works initially, I am at a loss as to why this operation would fail afterwards.
Any help, much appreciated.
Many thanks,
Martin
in the multiple insert behavior, you are binding the product ID columns to the recordset rs_product.ProductID column.
the reason this wont work is because this recordset does not have any filtering, this means that the value in the recordset will always be the first record in the database, it will not use the value for the product that was just inserted.
On the product insert page, the product ID of the record that is created gets stored in a session variable named "WADA_Insert_products".
you should that session binding for the productID columns in the multiple insert behaviors.
