Current Theme and Edit Theme function
Thread begun 3/07/2012 1:58 pm by cj.tung395641 | Last modified 3/08/2012 6:48 am by Jason Byrnes | 3434 views | 7 replies |
cj.tung395641
I am experiencing trouble when I want to change current theme and edit theme function.
When I click edit them the page shown (please find the attached file) and when I change theme and update my home page, it still stay with same design.
Please let me know what went wrong here? thanks!
Chun-Jhen
first, delete the webassist/themes/temp_editing folder on the server.
then in the webassist/themes folder there is a sub folder for each theme, in each one is a file named theme_settings.xml.
in the theme_settings.xml file for each theme, change line 1:
<?xml version="1.0" encoding="windows-1256"?>
<?xml version="1.0"?>
cj.tung395641
Hi Jason, thank you for answering back so fast!
I couldn't find webassist/themes/temp_editing folder. I changed theme_settings.xml but still the same error messages and by the way my PowerStore is current version: 4.5.1
you may not have that folder in your local giles, you need to access the remote server to delete it.
cj.tung395641
Still can't find it either side. It's under install/webassist/themes right?
no, not under the install folder, it's in the webassist folder that is at the same level as the install folder.
cj.tung395641
Found them after restart my Dreamweaver. It works, thanks Jason.
you're welcome, glad to hear it is working.
