Problem with Framework Builder after installing Design Extender
Thread begun 3/07/2012 11:37 am by marcel303333 | Last modified 3/14/2012 12:18 pm by Jason Byrnes | 5320 views | 12 replies |
marcel303333
I have the following problem with Framework Builder since installing Design Extender.
I get the following code if I want to add another Plug-in page to a dynamic Plug-in:
((isset($WA_start_1315338972280))?$WA_start_1315338972280->Body:"")
instead of:
Willi Schneider
Hi Jason
Same problem here
Greetings
Willi
heres an updated copy of the Configuration/ServerBehaviors/PHP_MySQL/WebAssist/Framework/20-Insert Dynamic Plug-in.htm file that should correct the issue, for help finding the configuration forlder, see the common installation issues pdf:
it's a good idea to delete the cache file after replacing this file.
Willi Schneider
Problem changes
Hi Jason
The initial error is fixed, however if I try to add or remove a plugin from the GUI the changes are not recognized.
Greetings
Willi
marcel303333
I already told Ray about the problem Willi describes. I have the same problem here.
I sent an updated file to both of you from the support incident. We'll get an update out for Design Extender to address this issue formally sometime later this week.
Willi Schneider
Hi Ray
Thanks for the info. Everything works fine, except the small glitch in DW CS4, I've reported to you via Skype a few minutes ago.
However, this issue isn't affecting the functionality, so that's just to let you know.
Willi Schneider
Problem solved
Hi all
The design extender 1.03 release fixed all issues for me.
Thanks for your help.
Greetings
Willi
