Help creating a form using lookup codes
Thread begun 3/06/2012 3:18 am by saf01 | Last modified 3/13/2012 11:27 am by Jason Byrnes | 5292 views | 15 replies |
saf01
Hi. I want to create a registration form, without the need for username and password.
The user will already have a code that is emailed to them. The database contains the code.
The registration is only successful if the code entered on the code field on the form matches the one in the database otherwise the user cant register.
Please advise. Thanks
create form field to enter the code, and a recordset that will query the table holding the codes and filter it using the form element.
then in server valadtion, add numeric validation. set the server variable to "$totalRows_recordsetName" where recordsetName is the name of the recordset, set the minimum to 1 and the max to 100, this will pass validation only if he code is found in the database.
saf01
Thx for answer. Im really struggling with this. Ive created the form using CSS Form Builder 2 and added UE behaviour to it. Im going to add Datassist > Insert > Single Record Insert after I know this thing works.
Ive created a Recordset in Simple mode and then how do I filter using the form field (my form field is called txt_VCode?
In the server validation I already have a another WA Server Validations - do I add the new Server Validation to this one or do I add a new numeric validation as in:
Server Validations > Webassist > Validation > Server Validation ?
Please advise
in the recordset simple mod, set the filtering section to use the column that contains the code, then set it to Form variable and enter the form elements name:
txt_VCode
since you already have validation on the page, edit the server validation by clicking it on the server behaviors panel to add the new numeric validation.
saf01
Alright I went ahead and did exactly as described. If I add the correct code and fill in the rest of the form i keep getting register.php?invalid=true
Cannot modify header - header already sent error.
Is there anyhting I can do here? Cheers
see the following page for details on the headers already sent error:
showthread.php?t=19285
for the validation, inspect the page code and make sure that the recordset code comes before the validation code.
if you continue to have a problem send a copy of the page so i can see the code.
saf01
Hi Jason,
I remade the entire form from scratch - now I have no more errors and everything works as expected - tested, if the code is not entered correctly the form does not send, if the code entered correctly it sends email. My code field is alphanumeric, so I added an alphanumeric validation instead of numeric, it still works.
Is there a way I can add a message next to the Code field that says Invalid code if the code entered does not match the code in the database after hitting submit? I have Form Toolkit but, not sure about the redirect page part of it.
Thanks you very much for your help.
yes, use the validation show if server behavior to show validation errors if validation fails.
saf01
Thx for your help that worked.
Please can you help with this small thing. I have now another page, this page is a very simple datassist results page only with a recordset that list all items from a database with a repeat region. I want to add a link or button within the repeat region so when a user clicks on this button one of the fields (item name) on the VCode registration form is automatically filled with the name of the item the user has clicked on from the data assist results page?
EDIT: Its ok now Ive managed to do this - I added the same recordset that was on the results page to the register form page but did a URL parameter filter. On the results page I added a hidden field with the itemid and same on the form page on the item name field. Now I can pass the item id and name.
Please can you tell me how I can remove the Vcode from the database once the form has been posted - is this an easy thing to do? Thanks
add a delete record behavior, set the Key Column to the column that contains the code, set it to use the code form element. you will need to make sure that the delete behavior code gets added after the insert code.
