Remove <p> tags
Thread begun 3/05/2012 11:21 pm by troy310770 | Last modified 3/06/2012 11:51 am by Jason Byrnes | 3874 views | 3 replies |
troy310770
Remove <p> tags
I found on on the forum how to change to <br />, but is it possible to remove the beginning <p> and ending </p>.
My page has <p class="main-text"><?php echo $row_Content['home_maincontent']; ?></p> and the extra <p></p> are messing with the formatting.
CraigRBeta Tester
I asked this question a while ago.
Here's the result, hope it fixes your issue.
showthread.php?t=23024
troy310770
Thanks, I did see your post a earlier and did that. It changed the middle paragraph close and opens to br / but did not remove the beginning and ending.
Is it possible to remove them?
prevent P tags from being added at the beginning and end of new content areas, it wont remove the p tags from existing content areas, you will need to do that manually by switching the editor to source mode and deleting the p tags.
