cant edit the settings
Thread begun 3/05/2012 1:05 pm by Smart-FX | Last modified 3/05/2012 2:14 pm by Jason Byrnes | 1719 views | 3 replies |
Smart-FX
Cant edit the design for some reason. evrytime i try to edit the design i keep getting the HTTP 500 ERROR
and when i put the gallery into my page, it does not show currectly please help as this is for a client who is becoming very impatient.
Smart-FX
mannages to sort out the settings side of things but the gallery wont fit in a space of 600px, gallery is set to w350px x h300.
how do you change the size of the gallery background??
im using design layout Ribbon + Fullsize + Lightbox
Smart-FX
and as soon as you hit cancel in the design. you get the HTTP 500 ERROR
to change the width, go to the Choose design tab and click the settings link for the galery you are using.
in the images section, you can set the width of the thumbnails, large, and supper size images.
for the 500 server error, This usually happens as a result of file permissions issues.
to fix the problem, make sure that all files and folders under the /galleries folder are set to 755 permissions, you can do this in most FTP clients like filezilla by right clicking on the webassist folder in the file panel and selecting the Set File Permissions option, setting the 755 permission level then selecting the option to apply this to "Recurs into subdirectories" -> "Apply to all files and directories"
Also, edit the admin_gallery/common/properties.php file, change the following code:
$GLOBALS['permissions'] = array(
'dir' => 0777,
'file' => 0666
'dir' => 0755,
'file' => 0755
