insert page not storing session variable
Thread begun 3/05/2012 3:21 am by georgina_barrett_187762 | Last modified 3/06/2012 7:21 am by Jason Byrnes | 3218 views | 5 replies |
I have an insert page but for some reason it is not storing the id in a session variable, so when it goes to the detail page nothing is being displays (even though it is inserting into the database correctly). I know the problem is on the insert page and not the detail page as I tried to post the session variable in the url on the redirect of the insert page but it just shows a 0. I have compared it to my other insert pages but I cannot see any difference. I have attached the file.
on the insert page, change line 128:
header("Location: ".$WA_redirectURL);
session_commit();
if that doesnt work, to help troubleshoot, add the following code at line 1 of the detail page:
<?php @session_start(); ?>
and the following code just before the closing </body> tag of the details page to output the session being created:
<pre><?php var_dump($_SESSION); ?></pre>
post back the detail page and the session contents.
Adding session_commit didn't work.
I added the other code and when I loaded the page I got this at the bottom of the page
array(8) {
["loginlog_ID"]=>
&int(2397)
["EmpID"]=>
&string(2) "27"
["LoginLevel"]=>
&string(5) "admin"
["LoginGroup"]=>
&string(5) "admin"
["LoginName"]=>
&string(8) "Georgina"
["LoginFullName"]=>
&string(16) "Georgina Barrett"
["WADbSearch1_CustomerDetails_Results"]=>
&string(31) " AND (Surname LIKE '%barrett%')"
["WADA_Insert_BookingRequest"]=>
&int(0)
When I submitted the form it went to the detail page as before but didn't pass the session variable.
what is the structure of the table.
What is the data type for the BookingRequestID? is it set to INT? Set to be the Primary key and to auto increment?
Yes it is an auto-increment int and it is the primary key. It does insert the record ok it is just the redirect that isn't working. It used to work but for some reason it has stopped redirecting. I have attached a screen shot of the table.
