Form Validation Failing to re-populate user form data
Thread begun 3/04/2012 7:10 am by Paul | Last modified 4/02/2012 11:13 am by Jason Byrnes | 5504 views | 13 replies |
PaulBeta Tester
SA 2.0.4 in DW CS5.5
Error when the users email entry fails form validation (ie dupe entry), the registration page refreshes with original user data, but the radio group fails to populate with earlier user selection, returning instead the following errors against each radio; (I have replaced the original checked values set by the SA Wizard from "this" and "that" to 1)
array_search() expects parameter 2 to be array, string given in C:\xampp\htdocs\..\..\regme.php on line 167
checked="1" tabindex="5">
array_search() expects parameter 2 to be array, string given in C:\xampp\htdocs\..\..\regme.php on line 170
checked="1" tabindex="6">
The respective lines are as follows;
<div class="lineGroup">
          <label for="Registration_group_Membership_Type__1" class="sublabel" > Membership:<span class="requiredIndicator">&nbsp;*</span></label>
          <div class="errorGroup"> <span id="Registration_group_Membership_Type__1_Spry"> <span class="radioFieldGroup_Narrow"> <span class="radioGroup_Narrow">
          <label class="radioSublabel_Narrow" for="Registration_group_Membership_Type__1" onBlur="hideServerError('Registration_group_Membership_Type__1_ServerError');"> I am selling&nbsp;
            <input type="radio" name="Registration_group_Membership_Type" id="Registration_group_Membership_Type__1" value="1" class="formRadioField_Standard" <?php if (array_search("1", ((isset($_GET["invalid"]) && ValidatedField("regme","Registration_group_Membership_Type"))?ValidatedField("regme","Registration_group_Membership_Type"):array())) !== false) {echo "checked=\"1\"";} ?> tabindex="5">
          </label>
          <label class="radioSublabel_Narrow" for="Registration_group_Membership_Type__2" onBlur="hideServerError('Registration_group_Membership_Type__1_ServerError');">I am buying&nbsp;
            <input type="radio" name="Registration_group_Membership_Type" id="Registration_group_Membership_Type__2" value="2" class="formRadioField_Standard" <?php if (array_search("2", ((isset($_GET["invalid"]) && ValidatedField("regme","Registration_group_Membership_Type"))?ValidatedField("regme","Registration_group_Membership_Type"):array())) !== false) {echo "checked=\"1\"";} ?> tabindex="6">
          </label>
          </span></span> </span> </div>
        </div>
The original option button values applied by SA "this" and "that" have been replaced by 1 and 2, which are the values I want sent to MySQL according to user selection.
Any ideas?
Thanks.
can you send a copy of the full page in a zip archive so i can see the code in context to troubleshoot.
PaulBeta Tester
Jason,
Zipped file as requested.
i have reproduced this issue with security assist and logged it in our system as a bug to be corrected in a future update.
to work around the problem, you will need to manually remove the bad code and reset the initial value for the radio buttons.
in the first button, delete this code:
in the second button, delete this code:
in design view, select the first radio button, in the property inspector, click the Dynamic button, click the lightning bolt icon next to select value equal to, in the bindings panel, expand the validated entries collection and select the Registration_group_Membership_Type radio group.
PaulBeta Tester
Jason,
Thanks for prompt response.
This action resolved issue.
Glad to hear it is working.
PaulBeta Tester
I assumed if I wanted the same behaviour on my Checkbox, id follow the same solution, but it doesn't seem to work.
That is if the checkbox is selected, and for submit fails, the checkbox refreshes as empty.
check box is a little different, click the lightning bolt next to check if and select the corresponding validated entry. then in the equal to box, type the checked value for the checkbox.
PaulBeta Tester
I have applied your suggestion as per below;
<input <?php if (!(strcmp((ValidatedField("newreg_501","AcceptTerms")),1))) {echo "checked=\"checked\"";} ?> type="checkbox" name="AcceptTerms" id="AcceptTerms" value="1" />
However, the checkbox value is not being returned after the form validates and errors on submission.
any ideas.
please send a link where i can see the problem and a copy of the page.
