Security Assist Wizard Fails with "Error in applyFBSBS:" error
Thread begun 3/04/2012 5:39 am by Paul | Last modified 3/05/2012 1:45 pm by Jason Byrnes | 3175 views | 6 replies |
PaulBeta Tester
SA 2.0.4 with DW CS5.5
After using the wizard to configure the security pages, I click OK to continue build process.
The wizard proceeds to build the login page at 2:35 runtime, the process halts and throes the error;
ReferenceError: WAiRite is not defined.
The process stops with a partially completed login page sitting in the background.
Images of steps attached.
Gratefull for any advice on how to resolve.
Thanks,
PaulBeta Tester
This appears to have been resolved after removing CSS Form Builder 1.0.2 and Cookies Toolkit 3 from my active extensions. Then removing SA 2.0.4 completely, wiping the CS5.5 winfilecache and re-installing SA again.
Possible conflict??
Yes. Security Assist v2 includes Cookies toolkit, so they shouldn't be installed together.
Also Security Assist v2 uses Form Builder v2 functionality, so it has to be installed after Form Builder v1 to update some necessary files.
This is just another example of why we are moving to a consolidation of extensions to prevent some of these conflicts and confusion associated with so many products with different versions.
PaulBeta Tester
Thanks for the info Ray.
So am OK to have removed Form Builder 1 too, leaving just SA 2?
Thanks,
it would probably be a good idea to uninstall SA2, then reinstall to make sure the Form Builder 1 uninstall did not remove some shared files.
PaulBeta Tester
Done.
This action appears to have resolved issue.
thanks, Paul
glad to hear it is working.
