form not submitting
Thread begun 3/03/2012 12:03 am by jeff421281 | Last modified 3/09/2012 7:41 am by Jason Byrnes | 3985 views | 7 replies |
jeff421281
form not submitting
Hi, I used your CSS Form Builder, but I've been struggling to get the form to work and I'm not sure what I need to do. The validation won't accept; I'm not sure if the email works. Can you look at the file and steer me in the right direction. Thank you!!
you say "The validation won't accept", can you expand on that a little please.
Do you mean all validation?
Or a specific validation?
to help us track which validation is failing, change the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
    die($WAFV_Errors."<br />".var_dump($_POST)."<br />".var_dump($_SESSION));
this will write a bunch of information to the screen when validation fails, please post that back.
jeff421281
Hi Jason, thank you for taking the time to look at this. I've been working on this website for such a long time, I'm burnt out. Here is the error code, I swapped out my email address with my user name for posting purposes.
array(8) { ["Name"]=> string(4) "Jeff" ["Email"]=> string(21) "jeff421281" ["Feedback"]=> string(1) "2" ["Message"]=> string(9) "Hi there!" ["Security_Code"]=> string(6) "xk5wpt" ["Hidden_Field"]=> string(0) "" ["FeedbackContactForm_submit_x"]=> string(3) "164" ["FeedbackContactForm_submit_y"]=> string(2) "28" } array(2) { ["captcha_Security_Code_1"]=> string(6) "xK5wPt" ["WAVT_contact_Errors"]=> string(0) "" } ,4
The problem occurs when I'm trying to submit the form. It seems to get hung up with the Captcha validation. When the Captcha is entered correctly, it doesn't seem to recognize the entry and gives the "wrong validation" message.
The form is supposed to send an email with the "Your Name" field as the "From Sender" in the email, and the 'drop-down select menu' selection is supposed to be carried over to the email as the email's subject. I don't know if those things are conflicting with the form submission, but since the form isn't submitting I can't test those features out.
Thanks!!
in the server validation behavior, you have set the like entry validation fro the captcha to compare the "Security_Code" form element to the "captcha_Security_Code" session variable, this needs to be reset to use the "captcha_Security_Code_1" session variable instead.
jeff421281
Hi Jason, I made the change you requested thru the Server Behavior panel, however it's not accepting the Captcha entry. Below is the error code I'm receiving.
array(8) { ["Name"]=> string(4) "Jeff" ["Email"]=> string(21) "jeff421281" ["Feedback"]=> string(1) "2" ["Message"]=> string(17) "Howdy Licensing 4" ["Security_Code"]=> string(6) "44PZKm" ["Hidden_Field"]=> string(0) "" ["FeedbackContactForm_submit_x"]=> string(3) "183" ["FeedbackContactForm_submit_y"]=> string(2) "15" } array(2) { ["captcha_Security_Code_1"]=> string(6) "44PZKm" ["WAVT_contact_Errors"]=> string(0) "" } ,4
please upload the latest copy of the page in a zip archive so i can examine the code.
jeff421281
Here you go, thank you!!
