Todays eCart (5) errors
Thread begun 3/02/2012 8:47 am by Steve | Last modified 3/02/2012 5:58 pm by Steve | 4390 views | 17 replies |
Steve
Hello,
Today after duplicating values from a prior working cart and deleting those created from the wizard I find that moving to the checkout page yields the following error:
" Missing/Illegal Combination of Package/Dimensions "
I've added the echoing code as noted in this Thread:
showthread.php?t=15278
which yields the following empty results on the shipping_failure page
Direct Pay:
Full Request: n/a
Full Response: n/a
Express Authorize
Full Request: n/a
Full Response: n/a
Express Process:
Full Request: n/a
Full Response: n/a
UPS:
Full Request: n/a
Full Response: n/a
FedEX:
Full Request: n/a
Full Response: n/a
USPS:
Full Request: n/a
Full Response: n/a
Note: the cart/display page prior to checkout have identical eCart code so not sure what aspect to trace next?
the thread you reference is for code specific to power store.
what shipping provider are you using? In the bindings panel, there will be a binding group for your shipping provider, in that binding group is a binding for the full request and full response for that provider, add those bindings to the page.
Steve
Hi Jason,
Using UPS.
Results are as follows from adding the two bindings items:
Full Request:
--removed client details--Rating and Service1.0001Raterate015YA450
Dana PointCA92629US
030212in10in8inIN1.0LBS
Full Response:
Rating and Service1.00010FailureHard110602Missing/Illegal Combination of Package/Dimensions
Attached image showing the values set in the Extension... I will remove the 'in" after each value as that might be the problem...
yes, package length width and height should not include the dimensions, that is aded to the value by the Size Units setting.
Steve
Success...
Was able to fully checkout but one issue where the URL query string is still in the URL when passed to the checkout.php page causing an error.
For instance ...checkout.php?ProdId=5
what was the error?
was this coming from the cart page or another page?
on the page that contains the checkout button, go to the server behaviors panel and double click the checkout server behavior, make sure the address entered for the checkout page does not contain the uRL variables.
Steve
The error is a page failure/not found due to not being able to parse the queryString value.
The ProdId starts by existing on the Product Detail page.
Then the Checkout page link/checkout behavior fires on any $_POST (which I will change as I want to remain on the Product page after adding a product - as shown in attached image).
Once the value exists on the Display (Order summary page) it is retained and passed to the checkout page where the error causes a failure.
Checkout code:
//WA eCart Trigger Redirect Check Out
if ($_SERVER["REQUEST_METHOD"] == "POST") {
if (true) {
$eCart1->UpdateCart();
$eCart1->cartAction = "CheckOutUpdate";
$Redirect_redirStr="display.php";
if ($Redirect_redirStr != "") {
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") === false) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "Checkout";
Add to cart code:
// WA eCart AddToCart
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
if (isset($totalRows_rsProduct) && $totalRows_rsProduct > 0) {
$row_rsProduct = WAEC_findRecordMySQL($rsProduct, "ProductID", $ATC_itemID);
if ($row_rsProduct) {
$ATC_itemName = "".$row_rsProduct['ProductName'] ."";// column binding
$ATC_itemDescription = "".$row_rsProduct['ProductShortDesc'] ."";// column binding
$ATC_itemThumbnail = "".$row_rsProduct['ProductImage'] ."";// column binding
$ATC_itemWeight = floatval("".$row_rsProduct['ProductWeight'] ."");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_rsProduct['ProductPrice'] ."");// column binding
mysql_data_seek($rsProduct, 0);
$row_rsProduct = mysql_fetch_assoc($rsProduct);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
in the checkout button code, remove this chunk so that it will not append the query string:
      else     {
Steve
Perfect! Thanks
Now I just need the weights to properly calculate as no mater how many items in the cart the same Shipping cost is being returned. Any suggestions on where to look next?
what is the full code for the package weight option?
