Shopping Cart Powerstore V2
Thread begun 7/24/2009 11:59 am by info371156 | Last modified 7/24/2009 12:50 pm by info371156 | 2586 views | 2 replies |
info371156
if you update a quantity in the shopping cart (you enter a new number of quantity and press ENTER) - there is a suspiciouns redirect back to the products detail). this is not perfect if you have a long shopping cart.
same problem with pressing enter in products detail page.
is there a possibility to solve this?
It is probably clicking the "continue shopping" button instead of the "update cart" button when you hit return.
I think you might be able to fix it by setting the tabindex of the update cart button to be before the continue shopping button, or you could move the update cart button before it in the code as well. I think it happens because the first button after the form element where you are clicking return is the continue shopping button.
info371156
ok i fixed it in the cart with moving the button and in the details page with tabindex. thanks.
