Multiple inserts with session variable -- across spry panels
Thread begun 3/01/2012 1:03 pm by asarcona308398 | Last modified 3/01/2012 2:19 pm by Jason Byrnes | 966 views | 1 replies |
asarcona308398
I moved the form tag outside all the spry regions and have had no luck,
I also put just one form on the second spry panel only and within the insert multiple behaviors box "skip if" i choose to always insert and I can't seem to get an insert when using multiple inserts --- single inserts will work across the panels, this is also across a repeat selection
you reported this issue in another thread where i started a support ticket for you, we will assist you with this issue in that support ticket.
