Multiple record inserts with session variable
Thread begun 2/28/2012 12:23 pm by asarcona308398 | Last modified 7/17/2014 12:25 pm by Jason Byrnes | 5373 views | 9 replies |
asarcona308398
I can't seem to get multiple record inserts to work, although i can get a single insert to work.
the database records single inserts using a session variable set and passed from previous inserts on the same page, but if i change the single insert to multiple inserts using the same repeat region, and session variable, it records nothing...
any help much appreciated
to help troubleshoot, trey changing line 526:
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
echo($WA_Sql."||".$_SESSION['sg_instructor_instructor_id']."<br /");
asarcona308398
multiple inserts
Jason,
the session variable doesn't show on the page, but it is in the session file, and has a correct value.
attaching new file with ammendment to line 526
debbie295402
Multiple records insert doesn't insert and header warning error on submit
I think I have the same problem. I looked at the view source (below) and the session variables are not being inserted, or any other information showing. Warning on submit is: Warning: Cannot modify header information - headers already sent by (output started at /home/content/53/8580253/html/member_area/committeeSignup.php:59) in /home/content/53/8580253/html/member_area/committeeSignup.php on line 92. the page is within a member area so I have to paste code for you to view.
I've had a heck of a time with this and have had to undo a couple of times, close out dw, empty cache, then start over in order not to get errors when adding multiple insert. Please let me know if you need any additional information
code is sent by pm.
Looks like there are blank lines between closing php tags:
and opening php tags in the code:
that will cause the headers already sent error.
For the trigger, you are using Current Page submit, try changing that to Button submit pressed, or any form post instead.
NOTE: in the future, please don't paste the page code to your message, instead attach a copy of the php page.
debbie295402
Apologies for the text, but I've gotten used to support sites that don't take attachments. Noted for the future.
Removing the spaces worked to remove the error, however the information is still not posting to the database.
Additionally, within the member area I'm using the session variables to display personalized info but the session variables aren't displaying initially (Hello [sv] [sv]). If I go to the member update page, don't make any changes, then go to the signup form the session variables display correctly.
Also, apologies for the late reply. I responded to this over a week ago, but my system crashed before this posted. Been installing software for the last 3 days after a week out of commission.
update:
after trying to work through this I find that none of the session values for the logged in use are being displayed, eve if I go to the update page (which works fine). So I'm unable to grab the logged in user id or other session values and display them on the page and/or add them to the fields to be inserted. It is displaying the first field values of the database. New file attached.
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
debbie295402
dshsolutions
I can be available whenever you need. I'm online now. I'm in Cali PST
we looked at this in a connect session, I pointed to the manage relational table tutorial for details on how to accomplish the end goal.
http://www.webassist.com/tutorials/Manage-relational-tables
