Warnings
Thread begun 2/28/2012 7:37 am by rob294118 | Last modified 2/28/2012 9:07 am by Jason Byrnes | 2260 views | 3 replies |
rob294118
Warnings
Why am I getting these errors when my contact.php form loads?
Warning: session_start() [function.session-start]: open(/var/chroot/home/content/40/4430740/tmp/sess_rbou689ku86jt6cse5hdpffqn0, O_RDWR) failed: No such file or directory (2) in /home/content/40/4430740/html/thevoiceoverchick/webassist/form_validations/wavt_validatedform_php.php on line 3
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/content/40/4430740/html/thevoiceoverchick/webassist/form_validations/wavt_validatedform_php.php:3) in /home/content/40/4430740/html/thevoiceoverchick/webassist/form_validations/wavt_validatedform_php.php on line 3
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/40/4430740/html/thevoiceoverchick/webassist/form_validations/wavt_validatedform_php.php:3) in /home/content/40/4430740/html/thevoiceoverchick/webassist/form_validations/wavt_validatedform_php.php on line 3
these errors mean that the session.save_path setting in the php.ini file points to a location that does not exist.
you will need to contact the host to have them correct the problem.
rob294118
I don't even see a session.save_path in the php.ini how can I add it?
I've used this with Godaddy in the past with no issues.
see this blog post for details:
resolving-php-session-save_path-problem-with-go-daddy/
