How to replace temp values
Thread begun 2/28/2012 6:20 am by Steve | Last modified 2/29/2012 9:18 am by Jason Byrnes | 1958 views | 3 replies |
Steve
Hello,
I created a Cart for a client that had not yet completed their Authnet and UPS account set-ups. I used temp fictional values when using the Wizard to create the necessary pages and continue work while the Client secured their account details.
Now with these account details in hand, where do I find them stored so that I can swap out the temp values with the correct ones?
eCart version (Current latest release)
on the confirm page, double click the Local Checkout server behavior in the server behaviors panel to edit the authorize.net settings and the UPS shipping server behavior to change the UPS settings.
Steve
Perfect.
Thanks Jason!
One more quick question... The API login for Authnet is actually the proper value for X_login? NOT "the Login ID used to access the Merchant Interface" noted in step 2 of 5 of the Local Checkout panel? This almost has me thinking the user Id used to login to Authnet Merchant web access...
yes, it is the API Login you should be using, not the authorize.net account login.
