Problem with Site Sculptor
Hello, I have a problem, I uploaded the site to my remote server, everything seems fine with the database and uploads, even with the connection file to the database, but when I start the installation process site with its own cms sculptor, I get the following message:
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/content/15/8862915/html/norente/index.php on line 34
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/content/15/8862915/html/norente/index.php on line 36
The code into the page is the following:
<?php require_once('Connections/citywiderealty.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_citywiderealty, $citywiderealty);
$query_agents = "SELECT * FROM agentsprofiles ORDER BY profileid DESC";
$agents = mysql_query($query_agents, $citywiderealty) or die(mysql_error());
$row_agents = mysql_fetch_assoc($agents);
$totalRows_agents = mysql_num_rows($agents);
require_once('WA_Globals/WA_Globals.php'); ?>
<?php require_once('WA_CMS/addtosite.php'); ?>
Where can be the mistake and correct it?
Thanks!!
