Another weird problem
Thread begun 2/27/2012 3:26 pm by newimage96814918 | Last modified 2/29/2012 6:46 am by Jason Byrnes | 3050 views | 5 replies |
newimage96814918
Okay I sent all the support files up to the testing server, but I must have sent an old set or somthing, my pages on update all do that post right back to itself instead of going to the list. Is there a library file up dated somthing that fixes that up there or a quick code fix.
and agian it seem to only be happening up htere not on my testing severe on my computer. Is there a file I'm missing or somthing?
Tracy
In the data assist download page, there is a known issue pack with an updated library .php file that should correct the problem.
newimage96814918
I sent up the library file from that sticky post, is that the same one?
I even tried commenting out the line suggested in that stickky post, with no avail,
what is wierd is it is only up there, it works here on both my systems so I must not somthing the same.
I will try the library file from the dowload eare next.
Tracy
newimage96814918
Nope I sent it up with no avail, works fine though again back here????
Tracy
newimage96814918
I just don't know! I cannot see what I could have missed. I think I'll just delete everything up there and resend it all backup to make sure all is good then if there is the same issue I
'll get back at ya.
Thanks again for all your help!
Tracy
Ok, if you continue to have the same problem, I'll start an incident to look into it with you.
