help with check out
Thread begun 2/27/2012 12:37 pm by hostmaster336780 | Last modified 2/29/2012 1:52 pm by Jason Byrnes | 5378 views | 12 replies |
hostmaster336780
help with check out
I don't know what I'm doing wrong but no one can buy on my website help pls my search page is Search.php and i use website payments pro from paypal and the paypal button doesn't even work wtf
hostmaster336780
gonna try to delete everything and start over........................
hostmaster336780
well its still not working anyone here to help?
well, when i go to your detail page:
Detail.php?RazorNumber=AC-1000
it gives an error:
Warning: require_once(../WA_eCart/razorcart_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/87/8825987/html/Templates/Detail.php on line 3
Fatal error: require_once() [function.require]: Failed opening required '../WA_eCart/razorcart_PHP.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/87/8825987/html/Templates/Detail.php on line 3
this means that the WA_eCart/razorcart_PHP.php file has not been uploaded to the server, make sure to upload the WA_eCart/ folder to the server.
hostmaster336780
sorry a php programer tried to fix it and messed it up more pls look again i have it back so it goes all the way to the checkout pgs but it just won't work to check out and the paypal button still not working - on the confirm page it comes up
Warning: require_once(WA_eCart/razorcart1_PHP.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/87/8825987/html/confirm.php on line 6
Fatal error: require_once() [function.require]: Failed opening required 'WA_eCart/razorcart1_PHP.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/87/8825987/html/confirm.php on line 6
But i have no razorcart1.php idk were that is coming from? all I do have is razorcart.php
hostmaster336780
hello anyone here?
please be patient, we are available from 9am - 5pm Eastern Standard Time, Monday - Friday.
on the confirm page, there are 2 cart objects attached, but only one is being used.
find and delete the following 2 code blocks:
//WA eCart Include
require_once("WA_eCart/razorcart1_PHP.php");
$razorcart1
->GetContent();
to troubleshoot the PayPal button, add the following code to the pp_checkout_failure.php page:
@session_start();
echo
"<p>Express Authorize: <br />"
     echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />"
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br /></p>"
     echo
"<p>Express Process: <br />"
     echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />"
     echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>"
this will write the full request going to and the full response coming back from paypal to the screen.
NOTE: the full request and response will contain sensitive information that should be removed before posting here.
hostmaster336780
sorry this website has just been a pain. ok did what you asked on the confirm page it now say's
Fatal error: Call to a member function IsEmpty() on a non-object in /home/content/87/8825987/html/confirm.php on line 740
and the paypay info is in the file
Thank you so much for your time on this...
the eCart store order details behavior is using the razorcart1 cart object, you will need to edit it and change it to use the razorcart object instead.
also there are these 2 code blocks that reference the razorcart1 object
if ($razorcart1->IsEmpty()) {
$razorcart1->redirStr = "cart.php";
$razorcart1->cartAction = "RedirectIfEmpty";
// WA eCart Redirect
if ($razorcart1->redirStr != "") {
header("Location: ".$razorcart1->redirStr);
it looks like you had 2 cart objects at one time, and have run t checkout wizard for both, and the code for the other cart object is still left behind causing hte problenm, it may be worthwhile to delete the checkout pages and re run the checkout wizard.
for the checkout button problem:
the error coming back from paypal is:
Security header is not valid
this error happens if the API Credentials entered are for the live server, but the sandbox server is turned on, or vice versa.
hostmaster336780
ok i deleted all the pages and started over the paypal button is working i did not try the credit cards on my site yet
I just tried the credit cards on the site and it still does not work............
and now i'm getting this with the paypal button...But only sometimes?
Bad Request
Your browser sent a request that this server could not understand.
Size of a request header field exceeds server limit.
Cookie: TS2da579=01e27972b5c2fd98ca7995bebf5821c5c606fa037f06b2114f4d301bfaa6df63a67efab4a0e245897adb99a7ba64fcf83ecccf3489d9b1b617ced6c6f73a617aee1faa66994b25e9bc79c4fd52cd3ebeae122550dd628b678e16e9
