Error when i try to make a new few Dynamic links
Thread begun 2/27/2012 3:09 am by Morgan | Last modified 2/27/2012 9:02 am by Jason Byrnes | 4287 views | 1 replies |
Morgan
Hi have serious problem with creating new dynamic links.
Get the following error:
error occured in updateProgressPanel: TypeError: document.wholePage.document.CurrentRemoteFile has no properties
Verry annoying!!
If i create one Dynamic Link set, it works after i have change a few paths, but as soon as i try to edit and add a few more dynamic links everything brakes and i get errors!
Even when i add all the dyn links from start it breaks and adds some extra php code in the index-file and removes all the php-code in the menu.php file. :S
MenyWriter is getting more and more hard to work with, no smoothness just pain in the ass and redos and redos and get the same result = Not working!
I have deleted Catche ive started over and over still the same **** (sorry for my selections of words).
Regards
Morgan
/* Update! */
Even after i got the error above i got it too work this time, but still annoying!
Badger
Error occurred in updateProgressPanel
This post has been deleted.
Dave W
TypeError:statusArea has no properties
I am getting a similar error to the above except mine says "TypeErropr:statusArea has no properties.
I have deleted cache file several times with no luck, also un-installed and reinstalled Design Extender.
I can add one dynamic menu but as above if I try to add another I get the above error. I also have tried adding all the dynamic links at once and still get the error.
I don't remember having this problem when I used CSSMenu Writer before, it only seems to have started since installing Design Extender.
I have Data Bridge, eCart, Free Tools and Design Extender installed. I followed the install procedure suggested, installing Design Extender last.
I am on a time limit with the site I am working on, so a quick response would be appreciated.
I am using DW CS6 on Windows 7 (32 bit)
Antonino Stancampiano
css menu writer -Design Extender
Dw CS6 - Design Extender1.1.1 css menu writer doesn't work when i try to filter record...I obtain several errors and i must to clean Dreamweaver's cache...I try to create a dynamic menu with categories and sub-categories...
What are the errors you are getting?
if i try to filter category with categoryParent = 0 for exemple i get a few line on menu.php like i aspect a url or post parameter isset()...isset is without argument...if i eliminate the code is ok...but when i try to filter to obtain sub-category on categoryParent the process cause errors and menu.php isn't totally written so i get a page incomplete that cause several errors when i start again the tool cssmenuwriter...
I have opened a support ticket so that we can look into this issue with you directly. Please update the incident with a good time and number to reach you and we can investigate this together to determine the cause of this bug and make sure to get it fixed.
