PowerStore V2 Product Picture Upload
Thread begun 7/24/2009 8:30 am by info371156 | Last modified 7/24/2009 11:35 am by Ray Borduin | 4116 views | 4 replies |
info371156
please close problem is fixed.
What was the issue? Anything someone else can benefit from knowing?
info371156
Picture Upload Powerstore V2
after installing powerstore to the webserver, the permissions for uploading files to images/upload must be set (Read, Write, Modify).
mick106153
Ray, could you flesh out how this is done since I am having the same problem on my local server, haven't put it up on my remote yet.
Solution would be the same in both cases?
Mick
I believe you can use: IUSR_Machinename as the user and give them full read and write access... in windows you can right click on a folder and set the properties on the Security tab.
