Set Cookie Value mistake in Help Section
Thread begun 2/26/2012 12:50 pm by h150477 | Last modified 2/27/2012 7:35 am by Jason Byrnes | 991 views | 1 replies |
h150477
Set Cookie Value appears twice in the Cookies Help section.
Once it points to:
ct_ft_03_01.html
and again to:
ct_ft_04_01.html
They are both different but appear to be different versions of the same instruction set.
Which one is the correct one?
Found when creating a comprehensive PDF of all the help system.
they are both correct.
one is a server behavior, it creates server side code to create a cookie that is triggered from a server event like the value of a submitted form field.
the second one is a client side behavior that creates javascript code to set a cookie based on a client side event such as the onClick event of a button, or onBlur event of a text field
