View Details and next/last page buttons not working
Thread begun 2/23/2012 2:11 pm by hostmaster336780 | Last modified 2/24/2012 1:42 pm by Jason Byrnes | 4975 views | 10 replies |
hostmaster336780
View Details and next/last page buttons not working on my results page and I can't find why any help would be nice thank you... My testing site is www.cwsontheweb.com
i dont see where the results are being displayed on your site. Please give some details for how to get to the search and results.
hostmaster336780
it is at the bottom of the index.php page (page_more26) starting at line 999 also getting Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/87/8825987/html/index.php:10) in /home/content/87/8825987/html/WADbSearch/HelperPHP.php on line 11 at the top of my results page
yes, i see it in your code, but when i go to the link you provided, i do not see it in the browser, so am not able to investigate, I am asking how to see the results on your site to reproduce the problem to get an idea of where to look.
hostmaster336780
try page_more25 that is were the search page is than hit search and you'll see the results page
you are using a non standard way of creating the site that is causing the issue.
you will need to recode the logic for the next, previous and last links to fit the URL rewriting scheme you are using.
for example, the code for the next link looks like this:
<a href="<?php printf("%s?pageNum_WADAretailchart=%d%s"$currentPagemin($totalPages_WADAretailchart$pageNum_WADAretailchart 1), $queryString_WADAretailchart); ?>" title="Next">
which is generating the following link:
index.php?pageNum_WADAretailchart=2&totalRows_WADAretailchart=1193&S_Brand=&S_RazorNumber=&S_Style=&S_OEMNumbers=&S_Length=&Search.x=53&Search.y=14&Search=Search
to work with your rewriting scheme, the link needs to be:
pageNum_WADAretailchart=2&totalRows_WADAretailchart=1193&S_Brand=&S_RazorNumber=&S_Style=&S_OEMNumbers=&S_Length=&Search.x=53&Search.y=14&Search=Search#!/page_more26
so the link code would need to be:
<a href="<?php printf("?pageNum_WADAretailchart=%d%s",  min($totalPages_WADAretailchart$pageNum_WADAretailchart 1), $queryString_WADAretailchart); ?>#!/page_more26" title="Next">
it looks like your system wants to have the querystring variables first, followed the code to load the certain part of the page
so for the detail page links, change:
<a href="#!/page_more27?RazorNumber=<?php echo(rawurlencode($row_WADAretailchart['RazorNumber'])); ?>" >
<a href="?RazorNumber=<?php echo(rawurlencode($row_WADAretailchart['RazorNumber'])); ?>#!/page_more27" >
the error message you are seeing is caused by having the recordset and Data Assist search code inside the body of the page, this code needs to be before the doctype tag. having it inside the body of the page is causing the headers already sent error message.
hostmaster336780
ok I changed the code to what you gave me but now it goes to the details page but the page is blank also can you tell me what lines need to get moved up to the doctype tag to remove the error messages? and there is also code now showing up on the results page... Also i fixed the next buttons but are the other buttons the same code if not can you let me know what they are? and the search results will not show up on ie only on firefox
hostmaster336780
is anyone here that can help me more?
the code that needs to be moved is at lines 1001 - 1150:
<?php require_once('Connections/razorretail.php'); ?>
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAretailchart;
//Searchpage: Search.php;
//Form: WADASearchForm;
$WADbSearch1_DefaultWhere "";
if (!
session_id()) session_start();
if ((isset(
$_GET["Search_x"]) && $_GET["Search_x"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
  //comparison list additions
$WADbSearch1->addComparisonFromEdit("Brand","S_Brand","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("RazorNumber","S_RazorNumber","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Style","S_Style","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("OEMNumbers","S_OEMNumbers","AND","Includes",0);
$WADbSearch1->addComparisonFromEdit("Length","S_Length","AND","Includes",0);
//save the query in a session variable
if (== 1) {
$_SESSION["WADbSearch1_Results"]=$WADbSearch1->whereClause;
else     {
//get the filter definition from a session variable
if (== 1)     {
    if (isset(
$_SESSION["WADbSearch1_Results"]) && $_SESSION["WADbSearch1_Results"] != "")     {
$WADbSearch1->whereClause $_SESSION["WADbSearch1_Results"];
    else     {
$WADbSearch1->whereClause $WADbSearch1_DefaultWhere;
  else     {
$WADbSearch1->whereClause str_replace("\\''""''"$WADbSearch1->whereClause);
$WADbSearch1whereClause '';
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
  if (
PHP_VERSION 6) {
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
$currentPage
$_SERVER["PHP_SELF"];
$maxRows_WADAretailchart
20;
$pageNum_WADAretailchart 0;
if (isset(
$_GET['pageNum_WADAretailchart'])) {
$pageNum_WADAretailchart $_GET['pageNum_WADAretailchart'];
$startRow_WADAretailchart $pageNum_WADAretailchart $maxRows_WADAretailchart;
mysql_select_db($database_razorretail$razorretail);
$query_WADAretailchart "SELECT Brand, RazorNumber, Style, OEMNumbers, Length, CenterHole, OuterHole, CtoC FROM retailchart";
setQueryBuilderSource($query_WADAretailchart,$WADbSearch1,false);
$query_limit_WADAretailchart sprintf("%s LIMIT %d, %d"$query_WADAretailchart$startRow_WADAretailchart$maxRows_WADAretailchart);
$WADAretailchart mysql_query($query_limit_WADAretailchart$razorretail) or die(mysql_error());
$row_WADAretailchart mysql_fetch_assoc($WADAretailchart);
if (isset(
$_GET['totalRows_WADAretailchart'])) {
$totalRows_WADAretailchart $_GET['totalRows_WADAretailchart'];
} else {
$all_WADAretailchart mysql_query($query_WADAretailchart);
$totalRows_WADAretailchart mysql_num_rows($all_WADAretailchart);
$totalPages_WADAretailchart ceil($totalRows_WADAretailchart/$maxRows_WADAretailchart)-1;
if (!empty(
$_SERVER['QUERY_STRING'])) {
$params explode("&"$_SERVER['QUERY_STRING']);
$newParams = array();
  foreach (
$params as $param) {
    if (
stristr($param"pageNum_WADAretailchart") == false &&
stristr($param"totalRows_WADAretailchart") == false) {
array_push($newParams$param);
  if (
count($newParams) != 0) {
$queryString_WADAretailchart "&" htmlentities(implode("&"$newParams));
$queryString_WADAretailchart sprintf("&totalRows_WADAretailchart=%d%s"$totalRows_WADAretailchart$queryString_WADAretailchart);
//WA AltClass Iterator
class WA_AltClassIterator     {
  var
$DisplayIndex;
  var
$DisplayArray;
  function
WA_AltClassIterator($theDisplayArray = array(1)) {
$this->ClassCounter 0;
$this->ClassArray   $theDisplayArray;
  function
getClass($incrementClass)  {
    if (
sizeof($this->ClassArray) == 0) return "";
      if (
$incrementClass) {
      if (
$this->ClassCounter >= sizeof($this->ClassArray)) $this->ClassCounter 0;
$this->ClassCounter++;
    if (
$this->ClassCounter 0)
      return
$this->ClassArray[$this->ClassCounter-1];
    else
      return
$this->ClassArray[0];
?><?php
//WA Alternating Class
$WARRT_AltClass1 = new WA_AltClassIterator(explode("|""WADAResultsRowDark|"));
i think that code being in the wrong place is part of the reason the details are empty
also, change the link to the details to us:
<a href="?S_RazorNumber=<?php echo(rawurlencode($row_WADAretailchart['RazorNumber'])); ?>&Search.x=53&Search.y=14&Search=Search#!/page_more27" >
the change for the other buttons will be the same change. Here is the original code for the next button:
the changes i made, where to remove the first %s, so:
<?php printf("%s?pageNum....
was changed to:
i then deleted the currentPage variable reference:
$currentPage,
and added #!/page_more26 after the closing php tag, so
...?>" title="Next"...
became"
...?>#!/page_more26" title="Next"...
hostmaster336780
the details page is still empty and the error message just moved to the top of the website any more ideas and also the search is still not working in Internet Explorer
