Dreamweaver CS5.5 Error with Data Assist 2.1
Thread begun 2/23/2012 2:09 pm by Jhthr228740 | Last modified 3/05/2012 10:45 am by Jason Byrnes | 3311 views | 5 replies |
Jhthr228740
We've tried several times to load the Data Assist on. This is the js error we receive:
While executing onLoad in WA_AppBuilder.htm, the following JavaScript error(s) occurrred:
At line 433 of file "user:Library:ApplicationSupport: Adobe: DreamweaverCS5.5:en_US:Configuration:Commands:WA_AppBuilder.js":
APP_OBJ.layoutOptionInfo[pageType] has no properties
This is on MAC Dreamweaver CS5.5 - if anyone can offer some help I would appreciate it.
before starting the data assist wizard, make sure that you have defined a dynam,ic site in Dreamweaver, have created a new php page and saved it to the site, and have that php page open.
se the "Defining a Dynamic Site in Dreamweaver" tutorial on the learning resources page:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
Jhthr228740
Set-up a testing server and connected still error
Here is the js error I'm still receiving when I try to use the wizard:
While executing unload in WA_AppBuilder.htm, the following JavaScript error(s) occurred:
At line 433 of the file "Library: Application Support: Adobe Dreamweaver CS5.5: en_US:Configuration:Commands:WA_AppBuilder.js": APP_OBJ.layoutOptionalInfopageType] has no properties
Any suggestions?
have you tried Deleting the Dreamweaver Cache file from the users configuration folder:
Jhthr228740
Yes - deleted file and reinstalled and delted again
Still receiving the same js error -
