Custom Send New Password doesnt return to login.php
Thread begun 2/23/2012 2:03 pm by Christopher West | Last modified 2/24/2012 10:19 am by Jason Byrnes | 4129 views | 6 replies |
Hi there an odd problem, I have created a lost password page, it seems to update the password in the database, but doesnt go to the login page instead it stays on the same page.
I have attached the file.
I have setup a WebAssist Random Password in bindings, then in Server behaviors I have set up Session variable to the Random Password Binding. The created an Update page to then save this password as an encypted password. Finally I used the Secruity Assist 2 Email Password and linked it to the Session Variable.
The attached file is a dynamic plugin thats being called from Login.php (the default dynamic plugin is the regular login form) and so the URL .php?status=forgot calls the attached php file.
FYI The username is the Email address (since I prefer login systems that use email addresses)
sending screenshots in case they help.
BTW when I set up the WebAssist Random Password for some reason it didnt create "wa_randompassword.php" in the default WebAssist folder in my project directory...instead it created a new WebAssist folder outside my project - so i had to manually copy and paste it into the correct directory.
Further more the "Secruity Assist Email Password" automatically creates a UserName field in the email body section (which I had to manually change to my UserEmail field.
Please help :)
Chris
Looks like I solved it - I uploaded all the files to my hosting and it works - is there anyway I can configure my localhost testing server on my PC so that the email functionality works?
One problem that I am havng from the attached file in ym original post is that the Email that I get contains the encrypted version of the password - now I understand why because I had selected the UserPassword field - in the Secruity Assist Email Password Email Settings box I have selected 'Session.NewPassword' from the + icon but now my page goes to an error : Unknown column 'Session.NewPassword' in 'field list'
Any ideas?
Here is an updated file attached with my session variable problem (i had followed some other threads but those fixes didnt fix my problem with the following error:
"Unknown column 'Session.NewPassword' in 'field list'"
Not sure what to do :(
Chris
change line 72:
"selectColumns" => array("UserEmail","Session.NewPassword"),
"selectColumns" => array("UserEmail"),
Hi. I'm not sat at my computer at the mo, but read your solution, I'm curious, from your correction how does the session variable for the unencrypted password get saved to the email body? It's been referenced twice I believe so I'm assuming it's now only needed to be referenced only once. Is this correct thinking on my part?
this line tells it that there is a session:
"sessionVariables" => array("NewPassword"),
then in the mail body code:
"mailBody" => "User name: [UserEmail]\nPassword: [Session.NewPassword]",
it tells it to use that session.
