Adding New Products
Thread begun 2/23/2012 6:58 am by chuck429411 | Last modified 2/23/2012 10:39 am by Jason Byrnes | 2809 views | 4 replies |
chuck429411
Adding New Products
Hey Jason, I just added a new product section to my site. They are static items. I do not know if the calculations are working or not for these products. When I hit the atc button for one of those products, nothing gets added to the cart. I did not input a value for the CasePrice binding or the CaseBreak binding in the add to cart button panel. Could that be the reason? I left the size binding blank as well. The section is primarily for dispensing guns and the customer will not get a case price, case break or need to select a size.
chuck429411
Ok, I have figured it out for 6 out of 8 products. I just inputed the regular price into the CasePrice field and set the CaseBreak to 10. Those products quantities are set with a select list.
My final 2 products at the bottom have a text field for the customer to request as many of that item as they wish. These 2 items will not add to cart. Here is the link to the page in question. Scroll down to the bottom 2 products and add them to the cart and you will see what I mean.
equip.php
if i view source of your page, for the last item, the add to cart code looks like this:
<td rowspan="4" valign="bottom"><input name="eCart1_8_Quantity_Add" type="text" value="1" size="3" maxlength="3" />
          <input type="hidden" name="eCart1_8_ID_Add" value="300_006" />
          <br />
          <br />
          <form name="eCart1_8_ATC_300_006" method="POST"  action="/equip.php">
            <input type="image"  src="images/atc.jpg" border="0" class="eC_ImageButton" value="Add to Cart" name="eCart1_8_ATC">
  </form></td>
the problem is that the quatity text field and the ID hidden element are not inside the form tags. the form tags:
  </form>
only include the submit button. since the quantity and ID elements are outside the form tag, they are not submitted when the submit burton is pressed.
the add to cart code should have the quantity and id elements inside the form tag:
<td rowspan="4" valign="bottom"><form name="eCart1_8_ATC_300_006" method="POST"  action="/equip.php"><input name="eCart1_8_Quantity_Add" type="text" value="1" size="3" maxlength="3" />
          <br />
          <br />
  </form></td>
chuck429411
Thank you again Jason. That worked perfectly.
you're welcome.
