Sample Database files
Thread begun 2/23/2012 5:11 am by jo271221 | Last modified 2/23/2012 9:16 am by Jason Byrnes | 1877 views | 3 replies |
jo271221
I get an access denied error when I try to import the sample data files. The link to the download for the sample data files is on this page. design-extender_gsg.php
can you provide some more details please?
what is the exact error?
this is in PHPMyAdmin, right?
are you importing to the Local MySQL Server or the Remote MYSQL server?
Have you created a blank database first?
Is this blank database the active database?
jo271221
Database Sample Files
Yes, PHPMyAdmin, remote, active database, it was blank, then I added CMS and tried again and copied this error.
Here is the error message: SQL query:
-- MySQL Administrator dump 1.4
-- Server version 5.0.27-community-nt
/*!40101 SET @OLD_CHARACTER_SET_CLIENT=@@CHARACTER_SET_CLIENT */;
/*!40101 SET @OLD_CHARACTER_SET_RESULTS=@@CHARACTER_SET_RESULTS */;
/*!40101 SET @OLD_COLLATION_CONNECTION=@@COLLATION_CONNECTION */;
/*!40101 SET NAMES utf8 */;
/*!40014 SET @OLD_UNIQUE_CHECKS=@@UNIQUE_CHECKS, UNIQUE_CHECKS=0 */;
/*!40014 SET @OLD_FOREIGN_KEY_CHECKS=@@FOREIGN_KEY_CHECKS, FOREIGN_KEY_CHECKS=0 */;
/*!40101 SET @OLD_SQL_MODE=@@SQL_MODE, SQL_MODE='NO_AUTO_VALUE_ON_ZERO' */;
-- Create schema physical_goods
CREATE DATABASE IF NOT EXISTS physical_goods;
MySQL said: Documentation
#1044 - Access denied for user 'actualusernamehere'@'%' to database 'physical_goods'
this means that your user does not have privileges to use the create database command.
in the sql file, comment out the CREATE DATABASE IF NOT EXISTS physical_goods; line and the USE physical_goods; lines so that it will use the database you have already created instead of trying to create one.
