Resetting dynamic list
Thread begun 2/23/2012 1:10 am by bill3786 | Last modified 2/23/2012 1:04 pm by bill3786 | 3878 views | 8 replies |
bill3786
Is it possible to have the reset button on a search page perform a reset of a dynamic list/menu.
I have a "Please choose" static value at the top of the list and would like the reset button to reset any value showing in the list to the static value.
the reset button would need to be in its own form. you would want to add a hidden element to the form.
Then add code that is triggered on the hidden element to clear whatever variable is used for the dynamic list.
i cant really give specifics without knowing ow the list is set up. select the list in design view, then click the dynamic button in the property inspector, what variable is used for the select item equal to option? this is the variable that will need to be unset when the reset button is pressed.
bill3786
Does this screenshot give you enough information of the list on a datassist generated search page?
the select value equal to option is blank, the static option show each time the page is loaded.
perhaps i am missing something on what you are trying to accomplish....
bill3786
Sorry, the screenshot I sent you was from a search page and the reset button successfully resets the list to the static "please choose" option.
The problem was on a results page which has a search function. This does have a value in the "select value equal to" and it is <?php $row_WADAproducts["ProductName"] ?>
do you also want the reset button to reset the search results? or only reset the select list?
send a copy of the results page also so that i can see the full page code.
bill3786
Both the results and the select list.
none of your other form elements have a dynamic value, so why not just remove the Dynamic value from the set value equal to option for the list on the results page?
to reset the search, add the following link to the results page:
<a href="products_Results.php?reset=true">Clear Search</a>
then add the following code at line 1:
@session_start();
if(isset(
$_GET['reset']) && $_GET['reset'] == "true") {
    if(isset(
$_SESSION["WADbSearch1_products_Results"])) unset($_SESSION["WADbSearch1_products_Results"]);
bill3786
Because I already had a reset button alongside the search button I tried just deleting the dynamic value first and it works great, many thanks.
