Multiple File upload and insert from single form
Thread begun 2/22/2012 4:04 pm by jacob339944 | Last modified 2/23/2012 8:18 am by Jason Byrnes | 2905 views | 1 replies |
jacob339944
I found a thread that seemed to address the same situation I just found myself in. I have a single form where I need to upload multiple files and insert them as individual records in the database. I tried this to avail. Was wondering if you could take a look and see if I messed anything up. Here is the thread: showthread.php?t=21498
It uploads and inserts the first file, but then nothing, not uploading or inserting the other four files.
It's late, I'm tired and I can't see anything that appears wrong. Thanks for your help.
the problem is that you have added a redirect to the insert behavior:
$WA_redirectURL = "Files_Results.php";
it inserts the first record, then redirects to the Files_Results.php page before it has a chance to insert the other records....
change:
$WA_redirectURL = "";
then change this code:
if(sizeof($_SESSION['uploadedFiles']) > 0) {
  unset(
$_SESSION['uploadedFiles']);
header("Location: ".$WA_redirectURL);
  unset(
header("Location: Files_Results.php");
you cant set the redirect in the insert behavior for this, you have to set it manually in the code that unsets the session.
also, in your code, there are blank lines between code blocks, this can cause issues with the redirect happening.
see this post for details:
showthread.php?t=19285
