Duplicate lines
Thread begun 2/22/2012 12:23 pm by MikeH | Last modified 2/23/2012 4:00 am by Willi Schneider | 1890 views | 2 replies |
MikeH
Duplicate lines
Hi
Is there a way that FB plugins can be a little more intelligent?
If I make pages to plugin that have lets say an include for a script and a second page also has that script included FB plugins includes them twice causing issues. Is there a possability that this can be rectified in a future relase that files are only included once?
I have quite a few pages that have different (other dev extensions on) when included in the same page this line is repeated.
html:
<script type="text/javascript" src="../ScriptLibrary/jquery-latest.pack.js"></script>
I am having to comment them out at the moment except in one page yet everytime you reneter the 3rd party extension it puts them back and you comment them out again.
FB should technically only include it once shouldn't it?
Mike
this has been added as a feature request to be considered for the next version of framework builder.
Willi Schneider
Hi Mike
I guess you are using DMXzone Extensions, because that's where I'm having this problem.
So, first of all, I second your request for the next FB update.
But I found a quick and simple workaround for that.
In your plugin page, simply change that line
html:
<script type="text/javascript" src="../../ScriptLibrary/jquery-latest.pack.js"></script>
html:
if ("".$_GET['mode'] ."" == "test") {
} // ("".$_GET['mode'] ."" == "test")
So, if you include this file via WA's Framework Builder this line would be excluded. If you want to test that plugin "standalone", however, you should add that URL-parameter (mode=test) when previewing -->
myplugin.php?mode=test
You could create a code snippet for reuse.
HTH
Greetings
Willi
