Date validation errors - Invalid format
Thread begun 2/21/2012 11:22 pm by les179372 | Last modified 2/22/2012 11:06 am by Jason Byrnes | 2574 views | 3 replies |
les179372
Can anyone help?
When dates are chosen using the calendar all appears OK for the dates up to 12th of each month but dates chosen after this shows an invalid format.
The url is as follows: contact.php
Any help would be appreciated.
your date elements are using the dd/mm/yyyy format, but the spry validation is exprecting the mm/dd/yyyy fprmat.
change:
var Booking_Enquiry_group_Dates_From_Spry = new Spry.Widget.ValidationTextField("Booking_Enquiry_group_Dates_From_Spry", "date", { format:'mm/dd/yyyy' , validateOn:["blur"]});
var Booking_Enquiry_group_Dates_To_Spry = new Spry.Widget.ValidationTextField("Booking_Enquiry_group_Dates_To_Spry", "date", { format:'mm/dd/yyyy' , validateOn:["blur"]});
var Booking_Enquiry_group_Dates_From_Spry = new Spry.Widget.ValidationTextField("Booking_Enquiry_group_Dates_From_Spry", "date", { format:'dd/mm/yyyy' , validateOn:["blur"]});
var Booking_Enquiry_group_Dates_To_Spry = new Spry.Widget.ValidationTextField("Booking_Enquiry_group_Dates_To_Spry", "date", { format:'dd/mm/yyyy' , validateOn:["blur"]});
les179372
change:
Many thanks Jason,
Working perfectly.
Les
you're welcome.
