Repeating querystring on fail
Thread begun 2/21/2012 4:12 pm by Ian S | Last modified 2/22/2012 8:10 am by Jason Byrnes | 2462 views | 3 replies |
Ian S
Hi
Using server validations, if the validation fails I pass the fail=1 query string value.
If the form fails twice, this value gets passed twice. Three failures equals three instances of the query string value.
i.e
additem.php?fail=1&fail=1&fail=1&fail=1&fail=1&fail=1&fail=1&fail=1&fail=1&fail=1&fail=1&fail=1&fail=1
The validation code is
if (isset($_POST["BT_Submit"])) {
$WAFV_Redirect = "additem.php?fail=1";
$_SESSION['WAVT_additem_059_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["name"]))?$_POST["name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["stockcode"]))?$_POST["stockcode"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["description"]))?$_POST["description"]:"") . "",true,3);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"additem_059");
Can I stop this from happening and just pass the on fail value?
Cheers
Ian
add the following code at line 1 of the apge:
function cleanQS() {
$varQS ""
    if(isset(
$_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "") {
$arrRemove = array();
$arrRemove[] = "fail";
$arrQS explode("&"$_SERVER["QUERY_STRING"]);
        foreach(
$arrQS as $k => $v) {
$arrVar explode("="$v);
            if(
in_array($arrVar[0], $arrRemove)) unset($arrQS[$k]);
        if(
sizeof($arrQS) > 0) {
$varQS "".implode("&"$arrQS);
    return
$varQS;
if(isset(
$_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != ""$_SERVER["QUERY_STRING"] = cleanQS($_SERVER["QUERY_STRING"]);
Ian S
Top man. Thank you Jason
you're welcome.
