Special Instuctions
Thread begun 2/21/2012 10:27 am by johna1964 | Last modified 4/24/2012 12:10 pm by Jason Byrnes | 6715 views | 13 replies |
johna1964
Special Instuctions
Hi!
I need to add the ability for customers to type special order instructions on the cart page and carry over to the confirm page and be emailed to them within the same order confirmation email.
What is the best way to make thie happen? Or would it just need to be on the confirm page?
Do I insert a form from WA Form Builder?
Thank you!
johna1964
you would need to add the text field to the cart page and then save it to a session variable. It would be almost identical to adding the coupon code element as outlined in the "Creating a Coupon system for your eCart store" tutorial:
ecart_coupons_sr.pdf
follow the steps for creating the form and adding the session variable.
once set, the session variable will be available for you to use on the confirm page.
johna1964
Jason,
Thank you for the instruction!
Johna
johna1964
Hi again,
What do I need to do for this special instruction area to be sent with the order email ?
Thank you!
johna1964
in the email body, add the binding for the session that contains the special instructions.
johna1964
Thank you. I sort of understand what you telling me to do...
The steps to accomplish this:
confirm.php > double click on Univeral Email in Server Behaviors
select edit
add the code in this case:
<div><table width="740" border="0" cellpadding="5">
<tr>
<td width="382"><strong>Special Order Instruction</strong></td>
<td width="372">&nbsp;</td>
</tr>
<tr>
<td align="left" style="padding-bottom:20px;"><textarea name="SpecialInstruction" cols="50" rows="5"><?php echo $_SESSION['SpecialInstruction']; ?></textarea></td>
<td><p>&nbsp;</p></td>
</tr>
</table></div>
After this, I'm not sure what to do next... can you quide or correct me?
Thank you!
johna1964
you don't need to add the form element:
only the session binding:
after adding the session binding, save the email message, then click ok in AUniversal Email to except the changes and save and upload the files to the server.
johna1964
when I added the session binding to the email body it errored when I tried to save it. I would like it to be saved underneath the grand total. Do I not just place the <?php echo $_SESSION['SpecialInstruction']; ?> in code view underneath the code.
I've included a copy of the email page.
Thank you!
johna1964
what was the error? i cant help solve an error if i dont know the error message.
johna1964
Error Message:
While executing onLoad, the following JavaScript error (s) occurred:
At line 75 of file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS4\Configuration\Commands\WAUE_afterSave.htm":MM.WAUE_UI_FINISH has no properties
The page I sent to you is without the session binding... I was hoping you could let me know where to place it correctly.
I deleted the WinFileCache.dat - it still would not save without an error.
I don't know what to do... don't I place the code <?php echo $_SESSION['SpecialInstruction']; ?> within the email body; save; upload? I've been trying in various locations, but it continues to error - same error.
Thank you!
johna1964
