Content of HTML editor
Thread begun 2/21/2012 9:36 am by tops | Last modified 2/21/2012 12:42 pm by Jason Byrnes | 2858 views | 1 replies |
tops
Hello,
I want to pass the content of an HTML editor text box to another .php file in the URL, how can I do this?
Thank you
set the forms method to use GET, a form that uses the get method passes the form information as querystring variables.
johna1964
Hi!
What code needs to be entered into the action page in order to receive the content?
I tried:
<?php $_GET["editorField"]; ?>
and
<?php $_GET["newsletter2"]; ?>
but neither worked... am I close?
Thank you!
johna1964
no way for me to answer that without seeing the form
johna1964
Jason,
Here are the two pages.
Thank you for taking a look at this.
johna1964
the action of the form is admin_preview_newsletter.php and the name of the HTML Editor instance is "editorField"
so on the admin_preview_newsletter.php page, you could use this code to write the HTML Editor content:
<?php echo $_GET["editorField"]; ?>
johna1964
Jason,
Thank you - this works!
If you looked at the code I entered, I did not put echo in.
I need the echo!
johna
yup, you need the echo.
