virtual memory to big
Thread begun 2/21/2012 5:25 am by Fritz Stickers | Last modified 2/29/2012 8:23 am by Fritz Stickers | 4432 views | 10 replies |
Fritz Stickers
My provider lets me know that they get this error :
  A worker process with process id of '4056' serving application pool 'stickers.be' has requested a recycle because it reached its virtual memory limit.
My site is 45 Mb and has on the server 100 Mb virtual memory. Timeout is 60 minutes.
Because my site uses too much virtual memory, the application pool will be resetted and all sessions expired.
I inspected already all recordsets to be closed at the end of the pages.
Do you have an idea what can be wrong or how I can solve this ?
it could be any number of things wrong.
could be a recordset that returns more than 100mb worth of data.
could be a form that allows for uploading files and someone is trying to submit a file larger than 100mb
the error basically means that a page or pages in your site is trying to use more virtual memory than is available.
Fritz Stickers
My webshop 's recordsets are to filter images (average ± 25Kb), prices and data from customers. I don't use a form to allow uploading files.
I checked all recordsets for closing at the end of the pages and that is ok.
Last friday I moved my site frogstyling.be to stickers.be. Never had problems with frogstyling although stickers is just a copy. I only renamed all files, database, ... .
Now frogstyling has only redirects 301 for all pages.
Is there a way to detect the page(s) that uses unnecessary virtual memory ?
the only way I know of is to use the IIS debugger:
919790
Fritz Stickers
Do WA has an extension (for Asp VBScript) like the horizontal looper from T. Muck ?
This Horizontal Looper 2 is made with a "While ... Wend" statement. I red on "http://www.w3schools.com/vbscript/vbscript_looping.asp" that you shouldn't use this one, use instead the "Do...Loop" statement.
Can this causes my issue ?
In data Assist 2 there is a repeating table behavior for repeating a region horizontally and vertically.
It does use the While .... Wend syntax, but i don't think that is causing your issue.
In all honesty, I dont know why w3schools is recommending not to use the while ... wend syntax, I have used it successfully for about 12 years now without having any issues.
assuming that you add the while condition of the do ... loop statement at the beginning
Do While i < 10
some code
Loop
instead of adding the While statement to the Loop
Do
some code
Loop While i < 10
the only difference in using the while ... wend syntax:
While i < 10
some code
Wend
is that you drop the word "Do" and replace "Loop" with "Wend"
I cant see how using while ... wend would cause the problem you are reporting.
Fritz Stickers
I thought maybe it keeps creating unnecessary circulations from the recordset ?
all of the while loops i see on this page have a check to see if the recordset is at the end, for example:
while((numrows <> 0) AND (Not rsAstro.EOF))
the only way this will cause a memory issue is if the recordset select statement returns to many rows.
Fritz Stickers
I'am making my new page layout with the "looper" set on 4 columns and 4 or 5 rows.
I guess that will causes no problems ?
in my reply I was referring to the recordset, not the looper.
even if you set the looper to only return 4 columns and 4 or 5 rows, a memory issue may occur if your recordset returns an extremely large result.
using only 4 columns and 4 or 5 rows in the looper only effects how mush of the data returned by the recordset is used on the page, the recordset an still be much bigger
