Update Multiple Records not updating....
Thread begun 2/21/2012 2:11 am by Rune Brynestad | Last modified 2/22/2012 11:08 am by Jason Byrnes | 3384 views | 7 replies |
Rune Brynestad
Not sure whats going on here. Trying a simple test prior to trying to use on website.
Very basic multiple update not working at all. There is no error messages, just no updates.
I'm attaching my file. Appreciate your analysis.
Regards
Rune
to help troubleshoot the problem, add the following code just before the </body> tag and post back the output from this:
echo("region: ".$_SESSION['Region']."<br />");
echo(
"SQL: ".$WA_Sql."<br />");
echo(
"<pre>");
var_dump($_POST);
echo(
"</pre>");
Rune Brynestad
It goes like this for the first 6 records:
region: 7
SQL:
array(124) {
["WADA_RepeatID_Id_0"]=>
string(4) "1523"
["Prioritet_0"]=>
string(1) "1"
["WADA_RepeatID_Id_2"]=>
string(4) "1522"
["Prioritet_2"]=>
string(1) "2"
["WADA_RepeatID_Id_4"]=>
string(4) "1521"
["Prioritet_4"]=>
string(1) "3"
["WADA_RepeatID_Id_6"]=>
string(4) "1520"
["Prioritet_6"]=>
string(1) "4"
["WADA_RepeatID_Id_8"]=>
string(4) "1519"
["Prioritet_8"]=>
string(0) ""
["WADA_RepeatID_Id_10"]=>
string(4) "1517"
["Prioritet_10"]=>
string(0) ""
I have updeted the first 4
Regards
Rune
at line 7 you have the following if statement:
if ("".$_SESSION['Region'] ."" < "7") { // WebAssist Show If
that if statement is closed at line 180:
} // ("".$_SESSION['Region'] ."" < "7")
the code for the update record behavior is at lines 136 - 178, inside of that if statement.
the fact that the region session variable is 7 is causing the if to fail and the update to be ignored.
Rune Brynestad
Ok.
I have moved the closed if statement to line 135. The first record (the record with id 1523) is updated as it should be, the other records are not. The output is now:
region: 7
SQL: UPDATE `gavesoknader` SET `Prioritering` = '5' WHERE `Id`=1523
array(124) {
string(4) "1523"
["Prioritet_0"]=>
string(1) "5"
string(4) "1522"
["Prioritet_2"]=>
string(1) "6"
string(4) "1521"
["Prioritet_4"]=>
string(1) "7"
string(4) "1520"
["Prioritet_6"]=>
string(0) ""
string(4) "1519"
["Prioritet_8"]=>
string(0) ""
string(4) "1517"
["Prioritet_10"]=>
string(0) ""
I'm attching my updated file.
Regards
Rune
move the echo for the sql so that it is just after the update command line.
change:
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
echo("SQL: ".$WA_Sql."<br />");
Rune Brynestad
No difference I'm afraid. Only the first record is updated. The output is the same as before.
I'm attaching the updated file.
Regards
Rune
