Can't checkout
Thread begun 2/20/2012 7:13 pm by hostmaster336780 | Last modified 2/21/2012 9:27 am by Jason Byrnes | 1034 views | 1 replies |
hostmaster336780
Can't checkout
I don't understand what I'm doing wrong I use the checkout wizard than load on to my server and it never works any help would be nice.. My testing server is www.cwsontheweb.com I have gotten this - Unknown column 'AR' in 'field list' and many others but all about the same after I put in my address and click check out. also inside my cart when you update and add products the weight does not add up... Help pls.
to help troubleshoot the sql errors, make the following code changes
Line 365:
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error()."<br />".$WA_Sql);
Line 374:
To:
line 416:
$WA_editCmd = mysql_query($WA_sql, $WA_connection) or die(mysql_error());
$WA_editCmd = mysql_query($WA_sql, $WA_connection) or die(mysql_error()."<br />".$WA_sql);
line 426:
"also inside my cart when you update and add products the weight does not add up"
can you clarify what you mean by this? where do you expect to see the weight displayed?
