Adding more server validation
Thread begun 7/23/2009 5:34 pm by jeff_bannister384197 | Last modified 7/27/2009 7:11 am by Ray Borduin | 3097 views | 3 replies |
Hi All,
I have tried adding the client validation with the validation toolkit and that works fine. When I try the server validation .. (I am running a wamp server - Localhost/site) it does not work at all.
Any ideas?
Cheers.
How are you doing it? It would work if done correctly, because it was added in the first place, so the problem must be in the details you left out.
Hi Ray,
I am going into the server validation and adding it via the panel. If I do it via the client side it works fine. Does it have to have the re-direct defined on the server side validation?
Server side validation needs to be applied on the form action page. Maybe you are applying it on the wrong page?
