Double Captcha?
Thread begun 2/20/2012 1:26 pm by tangosdad | Last modified 2/21/2012 10:29 am by steelace396915 | 2193 views | 3 replies |
tangosdad
Double Captcha?
Not sure if I'm explaining this correctly but I do not need to have 2 Captchas on my forms. All I want is either the Image Captcha or the Secret Answer Captcha. How do I change this?
steelace396915
Hi
Im referring to one of the unmodified SA wizard pages (registration.php and the security answer field) in this example but the principle is the same.
You need to remove the following code from the page:
Spry validation code associated with that field located at the bottom of your page around row 605:
var Security_Answer_Spry = new Spry.Widget.ValidationTextField("Security_Answer_Spry", "none",{validateOn:["blur"]});
Then remove the whole div containing the form field starting with the code around row 552:
<div class="lineGroup">
<label for="Security_Answer_2" class="sublabel" >&nbsp;</label>
Ending with the closing div tag around row 573 just before the <span class="buttonFieldGroup" >
Finally you have to remove the Server Validation code associated with that field around row 26:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Answer"])?$_POST["Security_Answer"]:"")) . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,14);
This should accomplish what you want!
Regards,
Martin J.
tangosdad
Excellent Martin! Thanks very much!
steelace396915
You're welcome! Glad I could help!
Cheers,
Martin
