add 1 year to current date
Thread begun 2/20/2012 8:37 am by paul377172 | Last modified 2/22/2012 12:44 pm by Jason Byrnes | 4399 views | 8 replies |
paul377172
Hi, using the update record wizard what is the correct value i would enter into the date column when I want to update the current date by adding one year.
I have used this to add one year to the now date
<?php echo (date("Y-m-d h:n:s", strtotime("+1 year"))); ?>
thank you
gary.brett434358
Originally Said By: paul377172
thank you
Hi Paul, did you get this sorted? I have done this via sql recordset before but not in php?
In recordset try
tblPaulDateColumn,DATE_ADD(tblPaulDateColumn, INTERVAL 1 YEAR) AS FieldAliasName,
Cheers
Gary
entering the code you provided:
as the value for4 the data column in the insert record behavior do what you are asking.
paul377172
yes I managed to do it like you said Gary. Sorry not sure what you mean by your last sentance Jason.
The php code i entered into the update record behaviour date column is
<?php echo $row_Recordset2['DATE_ADD(renewal_date,INTERVAL 1 YEAR)']; ?>
which does indeed uodate the date by 1 year
thanks
in the insert record behavior, select the data column and use the code you provided:
as the value
paul377172
sorry if i am misunderstanding but i want to update a current record by adding 1 year to the current value, not add a new one.
My apologies, it was me who misunderstood. I missed the important word "update"....
on your update page, add a hidden form element. set the value of the hidden element to:
<?php echo (date("Y-m-d h:n:s", strtotime($row_recordsetName['DateColumn'],'+1 year'))); ?>
where recordsetName is the name of your recordset and DateColumn is the name of your data column
in the update behavior, bind the date column to the hidden element.
paul377172
Thanks Jason
you're welcome.
