Update for HTML Editor
Thread begun 2/20/2012 3:30 am by officeinfocom362633 | Last modified 2/21/2012 9:53 am by Jason Byrnes | 1749 views | 3 replies |
officeinfocom362633
Dear Sir
I start to use HTML Editor and I am very pleased about this extension that you offered us, it is a great tool.
My probleme is the update.
I use the same page for insert also for update.
Where do I have to change the code so I can use this extension in this way ?
PS
The original code was :
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("EditorArticole", "webassist/html_editor/", "100%", "200px", "Custom", "../custom/test_EditorArticole1.js", "");
I modify it in this way so he will act like "Sticky Note"
$WARichTextEditor_1 = CreateRichTextEditor ("EditorArticole", "../webassist/html_editor/", "740px", "400px", "Custom", "../custom/index_EditorArticole1.js", "".((isset($_POST["EditorArticole"]))?$_POST["EditorArticole"]:"") ."");
Thank You Very Much
it's really not a good idea to insert and update on the same page.
for an update page, you need to pass a querystring variable that contains the ID of the record to update, for example:
update.php?id=22
you use this id query string variable in a recordset to look up the record in the database, then use the record binding as the initial value in the HTML Editor instance.
when the update form is submitted, it needs to pass that ID variable again, to tell the update behavior which record to update.
officeinfocom362633
Thank You
Where can I find a complete tutorial about how this job can be done step with step,
where to be describe all the process from insert to update ?
DataAssist can help you create the pages for inserting or updating, or if you want to create them manually, see the Dreamweaver Help Documentation in the Building applications visually section:
WScbb6b82af5544594822510a94ae8d65-78d3a.html
